I was having the same issue. Do you have a USB flash drive connected? Are you sure it’s not downloading to the flash drive? That was the case for me. I removed the flash drive and it started uploading to the Artisan’s main memory
Just saw this reply. I power cycled the artisan and it started working
G29 L0 ; Load mesh
G29 A ; activate leveling
G29 J2; tilt mesh - this does a 4 point probe to generate the tilt
Thread is somewhat older, but still valid.
Yesterday i struggled also to upload files from Cura to the Artisan. I was confused, because i had it working already.
Solution: I had Luban also open the same time, this blocked Cura from uploading files to the printer. Closed Luban, tried again in Cura → worked!
