Cura for Artisan: installation
How can I install Artisan in Cura?
I can only find the other snap maker printers but not the Artisan…
Or is it just installing the machine settings manually?
If yes then which ones are they?
Build plate size, gcode fa or, what else?
I’m using this plugin: GitHub - Snapmaker/SnapmakerCuraPlugin: Snapmaker plugin for Cura 5
I believe it’s one of the two plugins that shows up in the Cura Marketplace when you search “Snapmaker”, but I’m not sure which one.
After that you’ll find Artisan in the list of supported printers. I haven’t been able to connect to it over the network, but my network is a bit weird so you may have better luck.
Thank you.
