Cura to Artisan wired network or wifi connection problem
Hi
I’ve just became a user of the Artisan. I used to use A350 with Cura and Snapmaker plugin with no problems.
Now when i want to connect Atisan to Cura i have no printer listeed in the network printer list - cura cannot lockate it.
Manual IP input gives no solution.
My cura version is 5.8.1
Snapmaker plug-in is installed.
Please suggest something.
The printer is connecting well via WiFi useing Luban.
Any ideas?
Regards
Lukasz
As far as I know, the Artisan is not displayed as a network printer.
You can add the Artisan as a local printer and if the Snapmaker plugin is installed, you can send the file to the Artisan via wifi after slicing.
