Completed print unraveling
Hi all,
I am experiencing an issue with my 3D prints i havent managed to locate an answer to anywhere on the web or these forums so i thought i woukd throw the question out to you good folks.
My 3D prints run fine, they adhere well with just a skirt, are strong and complete as expected with no visible issues. That is until i try to remove them from the bed. Then the initial layers start to unravel like pulling a thread on a sweater. And it just goes on and on, I could unwind the whole print this way.
The bed is always 60 degrees and the nozzle 200. I am using normal pva filament. Any thoughts?
You mean PLA?
I assume you mean PLA, not PVA. With PLA, I might offer two explanations: One might be underextrusion, i.e. the individual strands of plastic are too thin for the planned layer height and as a result are not squished together good enough. If that’s the case, you might see other effects like not completely filled surfaces. Solutions would be E-Steps calibration or increasing the flow rate. Reason #2 might be printing too cold, and therefore the layers not fusing good enough. Go 5-10° higher then.
The problem might be enhanced - and I seem to read this from your post - by the first layer sticking too well to the print bed. This may be your Z-offset being slightly too low, or - I’ve had this with the free spool of Snapmaker PLA that came with the kickstarter machine - the brand itself is bad and sticks to well - choose another filament brand then.
Edit: here’s a bit of additional tipps I found on the net: https://all3dp.com/2/3d-print-delamination-tips-tricks-to-avoid-layer-separation/
Yes I meant PLA - sorry not enough coffee yet!
Delamination!!! That was the term I was looking for. Thank you! I will go through the e-step calibration again and make sure that is correct.
Also when you mention 5 degrees higher is that nozzle, bed or both?
Cheers
Paul
the nozzle
Ok got it. Ill let you know how it goes!
How does your first layer look? https://blog.prusa3d.com/wp-content/uploads/2018/04/first_layer.jpg
