hello All !! some advice please is needed
if you look at the 5 mm image all seams fine with the project however if I go deeper to 6 mm Laban cnc 3x wants to shave part of the project down to meet the 6 mm request as i try even deeper the shave effect increases ? i also have up loaded the gcode
weather i generate the stl file in blender or Fusion i have the same result
5mm code------------------------------------
;Header Start
;header_type: cnc
;tool_head: standardCNCToolheadForSM2
;machine: Snapmaker 2.0 A350
;gcode_flavor: marlin
;renderMethod: line
;max_power: 255
;file_total_lines: 109929
;estimated_time(s): 11481.196
;is_rotate: false
;diameter: 0
;max_x(mm): 49.975
;max_y(mm): 31.325
;max_z(mm): 80
;max_b(mm): 0
;min_x(mm): -49.975
;min_y(mm): -49.975
;min_b(mm): 0
;min_z(mm): -0.553
;work_speed(mm/minute): 900
;jog_speed(mm/minute): 1500
;power(%): 0
;work_size_x: 320
;work_size_y: 350
;origin: center
;thumbnail: ===============
6 mm code -------------------------
;Header Start
;header_type: cnc
;renderMethod: line
;max_power: 255
;file_total_lines: 245285
;estimated_time(s): 36665.304
;is_rotate: false
;diameter: 0
;max_x(mm): 49.975
;max_y(mm): 49.975
;max_z(mm): 80
;max_b(mm): 0
;min_x(mm): -49.975
;min_y(mm): -49.975
;min_b(mm): 0
;min_z(mm): -1.107
;power(%): 0
;work_size_x: 320
;work_size_y: 350
;origin: center
;thumbnail:-----------------
PLATE FILTER GRID v2.stl_1739976563053.cnc (3.3 MB)
PLATE FILTER GRID v2.stl_1739976529971.cnc (1.5 MB)
