I have the gcode below to cut out a PCB via the CNC module. I can’t figure out why the machine is working at 3000mm/s - any thoughts? The GCode was generated by Flatcam 8.5 and I manually generated the header.
Thanks in advance for the help.
;Header Start
;header_type: cnc
;renderMethod: line
;file_total_lines: 114
;estimated_time(s): 30.36153183081994
;is_rotate: false
;diameter: 2.0
;max_x(mm): 130
;max_y(mm): 80
;max_z(mm): 0
;max_b(mm): 0
;min_x(mm): 0
;min_y(mm): 0
;min_b(mm): 0
;work_speed(mm/minute): 50
;jog_speed(mm/minute): 50
;power(%): 0
;thumbnail: data:image/png;base64,
;Header End
G21
G90
G94
F50.00
G00 Z5.0000
M03 S12000
G4 P1
G00 X14.9250Y-1.2270
G01 Z-0.4000
G01 X-1.2270Y-1.2270
G01 X-1.2270Y42.9250
G00 X-1.2270Y42.9250
G01 Z-0.8000
G01 X14.9250Y-1.2270
G01 Z-1.2000
G01 Z-1.6000
G01 Z-2.0000
G00 Z5.0000
G00 X-1.2270Y45.0750
G01 Z-0.4000
G01 X-1.2270Y89.2270
G01 X14.9250Y89.2270
G00 X14.9250Y89.2270
G01 Z-0.8000
G01 X-1.2270Y45.0750
G01 Z-1.2000
G01 Z-1.6000
G01 Z-2.0000
G00 Z5.0000
G00 X17.0750Y89.2270
G01 Z-0.4000
G01 X33.2270Y89.2270
G01 X33.2270Y45.0750
G00 X33.2270Y45.0750
G01 Z-0.8000
G01 X17.0750Y89.2270
G01 Z-1.2000
G01 Z-1.6000
G01 Z-2.0000
G00 Z5.0000
G00 X33.2270Y42.9250
G01 Z-0.4000
G01 X33.2270Y-1.2270
G01 X17.0750Y-1.2270
G00 X17.0750Y-1.2270
G01 Z-0.8000
G01 X33.2270Y42.9250
G01 Z-1.2000
G01 Z-1.6000
G01 Z-2.0000
G00 Z5.0000
G00 Z5.0000
G00 X0Y0
M05
