I have previously been able to connect my snapmaker to wifi but the other day I got a new phone and it wouldn’t see my wifi network. Updating my router firmware fixed that but now my 350 won’t connect to wifi. It still has a static IP in my router. I went to the experimental settings and tried resetting it but it must not have reset everything because it still pre-populates the wifi password. Typically forgetting the network and setting it up again fixes these sorts of issues but I can see no way to do that. Any ideas?
Check that your Router allows 2.4Ghz. If you are only broadcasting 5Ghz, you’ll have some devices that can not connect.
Some times having it 2.4/5 ghz set to a single ssid can have problems.
