it seems that I was delivered some wrong parts concerning the laser bed. Did anyone experience the same problems? I have received four laser bed parts in total, two identical ones each, two with four holes and two with two holes. Even when I only put all the parts together side by side they extend the space on the platform, where the laser bed should be mounted.
Thanks for your comments and your highly appreciated help in advance. This is my first new topic as I am a new user here - so sorry, if I did something wrong.
Even though the parts don’t match the pictures in the manual, you can still mount the 4 parts on the support frame without problems. I had the same happening with my A350.
I tried to mount them in the support frame but the parts do not fit the mounting holes for the screws because the parts are too wide. The right hand side is put for matching the holes … and then have a look at the other parts:
I can’t remember how I had the parts mounted (I have a print job going right now), but you could try to put the two with 4 holes in the middle and the other two on the outside mirrored.
this is so embarrasing … sorry for that … you are absolutely right. All parts are of the same width (80mm) but the embedded holes are in an offset. Changing the layout fixes my issue.
Thanks again, have a great christmas time and please stay healthy.
