Hi everyone,
I have set up my new Snapmaker F350 and it will not allow me to go past the “Calibrate the Bed” section. Any advice would be greatly appreciated. Is there a spot that the print head needs to be before turning on?
Are you able to do the last step where you lower the nozzle at the end until it touches the card?
Otherwise it’s probably an assembly problem. Double check your cables are plugged in correctly. Share photos of your machine (might have to use an offsite host since you’re new)
