Use case:
- Load my .STL file and view in the 3d print gcode generator
- Mess with the print quality settings and update the scale
- Generate .gcode and export that file to a USB stick
- Go print it. All works happily as it should.
But now a month later, I want to make a small tweak (can’t just use the original gcode) and reprint a second copy but I can’t remember what scale and print settings I used. I’ve figured out how to open the gcode file in the workspace, but it doesn’t load anything into the 3d print gcode generator, and I can’t find anything helpful in the workspace itself. Where can I find that data?
