can you only use the camera on the laser in wifi only ? it only seams to come up on the wifi not on the direct connection ?
Yes. It only works with wifi
@Melitta_Snapmaker @Edwin If this isn’t already planned, can you please make the camera also work by direct connection? Thank you.
It’s not technically possible.
There’s another thread that discusses this.
Then the hardware should be changed.
