Calibration after installing bracing kit on a A250
Just got the bracing kit and took the opportunity to install it since I needed to swap printer head and needed to take apart some of the printer anyway. No issues mounting them.
I also downloaded the latest firmware and selected that I have the bracing kit. Though the first section of that dialogue is confusing for me. Should I select Screws? The step in the manual (https://wiki.snapmaker.com/en/Snapmaker_2/manual/qsg_for_2_0_bracing_kit) shows nothing selected. I selected Screws, was that wrong?
Because when I run the calibration it starts off the heatbed, as It does not understand that I have the Y and X bracing plates installed… Also the prints start there, see photos.
What have I missed?
Manual or automatic calibration?
See point 3.3 in the Wiki you linked:
Selecting “Screws” means no Quick Swap kit - no connection to the bracing kit. The bracing kit is a separate selection.
I have both, QSK & bracing kit, and with both selected, I had no trouble calibrating.
Automatic calibration
