Autoleveling not saving the calibration Z-offset
Everytime I autolevel the printer seems to not “remember” the offset saved during autolevel.
Printer is a 350 with firmware1.13. I adjusted leveling sensor to 1mm above the nozzle. I tested the ABL with a knife and it stopped. I am about to try and do a factory reset to see if that helps. Any suggestions on how to solve this would be great.
I need an easy method of leveling since I print in 3-4 different materials.
When you perform a level, you are also required to set a Z Offset. It is not supposed to remember any Z Offset, because it is reset when you perform a level.
