Autodesk Fusion - Rotary Module - CNC milling
I am unable to use the Rotary Module in Autodesk Fusion.
The “Machining Type” tab is missing, so “Wrap” cannot be activated.
Could it be that this feature is not included in the free version of Fusion?
To my understanding, you can do limited indexed machining with the rotary and the free Fusion license, but if you want to go for true XYZA rotary machining you need the paid license.
Have you added the rotary motion to the Machine Definition?
I’m sorry, but I don’t understand what you mean.
I followed the tutorial at https://wiki.snapmaker.com/en/general/manual/using_artisan_with_fusion360_for_4axis_cnc.
There is no “Machining Type” tab, it is under “Multi-Axis” tab.
But it depends on which machining operation you choose, eg: Milling - 2D Contour - …
I have only the free personal version, and I can see “wrap”.
I’ve found it now.
Thank you for the hint.
