Artisan 4 axis Rotary Module - Postprocessor with Fusion 360
Dear Community;
Anyone with the Artisan solve the problem to work with Fusion 360 and use the Artisan with the Rotary Module 4 axis?
Snapmaker provide the postprocessor snapmaker-baxis.cps telling this is the right to use for 4 axis, but doesn’t work at all. Fusion 360 is telling errors all time when try to postprocess any file.
Anyone succeed in this?
Any help is appreciated.
Kind Regards.
Ed.
This way it could work if you have a free version of fusion 360:
Hope it helps.
i have the same problem with the postprocessor :frowning: so sad, I have finally spent the money for a full fusion 360 license especially to use the 4th axis…
I think it should work if you have the full version.
I would suggest to get in touch with support if you struggle.
Are you confident about generating carving gcodes with fusion 360? This is not a easy starting project.
Maybe a bit googling helps you further too:
