Auto bed-leveling before each print?
Hi all, newbie here… Just wanted to know if you need to do this or not. TIA
No, the bed levelling is saved to memory and loaded at machine power-on.
On my v1, I re-level every time I do a firmware upgrade, or change the toolhead. The toolhead change might be a bit excessive, but I occasionally print with a 0.04mm layer height. The firmware upgrade overwrites the saved calibration. I’m assuming that the v2 is the same.
Thank you for the quick response appreciate it! :smiley:
Good to know, thank you, I’ll keep this in mind as well. Appreciate the feedback! :smiley:
