Artisan Skip Forced Calibration
I’ve noticed with the Artisan that it makes me recalibrate the X/Y Offset every time I switch-in the Dual Extrusion 3DP module. This has become really annoying since it requires a relatively large amount of attention. TBH, it makes me rethink switching modules, which is really just sad given how much physically easier doing so is compared to the SM2.
I usually only print functional parts, so it’s extra annoying to have to go through the whole process of calibrating the X/Y offset. I also usually print PETG which doesn’t work well w/ the calibration, so I have to load two PLA filaments, calibrate it, then swap to PETG.
Is this normal that this screen displays/resets every time the module is swapped? Is there some way that I can bypass it?
Ok. So maybe it isn’t normal for that “Setup Completed” screen to come up with every boot. (It would show up every boot for me, but would allow me to immediately “Start Creating” unless I had swapped modules. Always felt weird, but I assumed that’s just how it was).
I decided to go nuclear and do a factory reset. I setup the 40W laser, did a FW update back up to 2.7.3, then the CNC, then the 3DP module. Now, It doesn’t show up on every boot, and I don’t have to recalibrate the 3DP head each time - thank heavens!
Fingers crossed that it continues this way (and that neither the Rotary Module or 2W IR laser that I haven’t setup yet ruin this sweet spot!)
I did notice that the 40W laser module now requires me to calibrate after swapping (I don’t recall if it did before), but that’s relatively easy compared to the 3DP module!
If any of the Snapmaker devs see this, I still think there’s a software bug or two in here somewhere. I did do a log dump prior to going nuclear and think I noticed something weird:
0,1970.01.01 08:00:36.130,DEBUG,SC,last toolHead sn list[9178, 9727]
36131,1970.01.01 08:00:36.131,DEBUG,SC,current toolHead sn 9727
36132,1970.01.01 08:00:36.132,DEBUG,SC,Last work type FDM
36134,1970.01.01 08:00:36.134,DEBUG,SC,Update work type FDM
1772078635441,2026.02.26 12:03:55.441,DEBUG,SC,set machine step 9178, 2
9727 is my 3DP, 9178 the 40W Laser. I find it weird that it is setting the “machine step” (which seems to control the setup step progression) for the Laser module while the 3DP module is attached. Don’t know if it’s always using list[0] or what…
Also noticed these two lines earlier:
34765,1970.01.01 08:00:34.765,DEBUG,SC,New tool head plugged or may changed, start setting up guide.
34766,1970.01.01 08:00:34.766,DEBUG,SC,set machine step 9178, 0
But they were only present the first time I added a module - never when the 3DP module was re-connected, so I kind of wonder if it somehow wasn’t saving when I’d click “Start Creating”, and then swapping the module would result in a bad state that caused it to silently go back to machine step 0?
Glad it worked for you!
Support does not read your lines unless you send it to them by opening a ticket:
https://support.snapmaker.com/hc/en-us/requests/new
