Hi guys,
I’ve made a pre-order for the A150 model but it seems to me that there is not much focus on the forum about this little model. Am I wrong?
Anyone received the A150? What do you think about it?
Thanks!
Hi guys,
Thanks!
The A150 is almost identical to the larger models the A250 and A350 besides the size difference. Almost everything you read about the A250 and A350 will be applicable to the A150.
Ok thanks!
Also the accessories will the same? What about the rotary module etc… ?
The accessories should be compatible with all models of SM2.0, there has been no information to suggest otherwise.
The A150 actually will likely be the model type with the least issues as some people are experiencing bed levelling issues with the larger models. The A150 with its smaller bed should be the most stable at least in the Y axis.
I think the rotary module will only be available for a250 and A350
Sorry the only module at this stage that isn’t compatible with the A150 is the rotary module, because the rotary module is too large for the A150.
