A350 Y-Linear noise
i have alreadyset up 3 times but always have noise in Y-linear
what’s happen~
Double check your cable connections. Make sure that the rails are plugged into the correct converters and then into the correct ports on the controller.
Where is your bed plugged in? Or is it currently unplugged?
Because on mine the power supply is just above the hand controller plug and then above that is the heated bed.
Otherwise you may have a bad limit switch:
Or you may have a bad rail and need to contact support.
For usb connection you may need to install drivers on your computer:
https://snapmaker.com/product/snapmaker-2/downloads
Wi-fi can send commands but you only get responses with the serial/mini-usb connection.
If your Z axis behaves normal, disassemble your bed and platform and connect a single linear module one by one to the controller and see if both modules work correctly.
Your homing position should be in the front.
Sorry for the late reply.
If any linear modules do not move, try to swap their ports on the controller when the machine is off. Control the linear modules via the touchscreen and you can see if the controller is faulty.
Edwin
