I’m doing a large print using Cura slicer. The print stop following to curve of the model at the back of the plate. Instead of following the curve around, it straight lines along the 320mm line of the build plate. I’m have the bracing and quick swap kits installed. I may have changed the start location in the machine’s software/firmware at some point in time. I know I had to calibrate the extruder, but don’t remember if I changed anything else. Not sure if the start code in Cura might be the culprit. Here’s the code. Is there a way to reset the machine firmware/software to default?
M104 S{material_print_temperature_layer_0} ;Set Hotend Temperature
M140 S{material_bed_temperature_layer_0} ;Set Bed Temperature
G28 ;home
G90 ;absolute positioning
G1 X-10 Y-10 F3000 ;Move to corner
G1 Z0 F1800 ;Go to zero offset
M109 S{material_print_temperature_layer_0} ;Wait for Hotend Temperature
M190 S{material_bed_temperature_layer_0} ;Wait for Bed Temperature
Here is the source about the print size, using quick swap and bracing kit:
You could reset the controller settings to factory defaults by entering M502 (for factory reset of the marlin controller) and M500 (for saving the new defaults).
You may need to set bracing and Quickswap kit on the touchscreen and level the bed again.
Been a while. Thanks for the reply. I did go ahead and reset the controller after copying down my extruder calibration #. I forgot that the bracer and quick swap kits stole 30mm from the back of the Y-axis and I was printing a piece that was 245mm deep. It would have been cool if the baseplate quick swap plate had moved the build plate forward 30mm to account for the space lost at the back of it. I could probably cut out a piece of aluminum stock to do that, then remove the two from the machine settings.
