I am new to this community forum, but I have had a 2.0 for just a few years now, I picked up a pair of the sb16 rails, made my own brackets with threads to adjust the height. then the quick swap came out. I had a hard time seeing these work together, then i had a stroke and a lot of things were put on the back burner for a while. So I picked up a set of the HGR20 rails, and sat on them for a few years thinking and trying different approaches, finally this last week came up with a viable method to incorporate them, posted a video on Utube explaining my thoughts and concerns, and the method I am using now. To me it seems to work with the quick swap. https://youtu.be/StU8jdI_SmQ is the link, let me know what you think, might be long winded, 5 minutes of your time. but i have not seen anyone else come up with a solution.the link is new, so it might take aday or 2
Looks nice, mind sharing your work for other users?
Anyway, thanks for sharing!
what other methods would i share?
I meant your stls and parts list.
it will take me a few days to get the organized, i am learning a lot about fusion at the moment, when i get the time i can get you the stl and parts list of what i used. i have bad habits and not so good at keeping the files organized . got to get better at that. .still haven’t the time to test out and see how solid the bed is for cnc. solid is best, it seemed like when i was adjusting the 4 corners, i would have them proud and the center would be .2 mm low. dont know how much spring is in the bed, and things of that nature. 14 x1 mm threads can have just a little force. hopefully i get some time to test it further,this weekend
