I am having issues with what I think may be a slicing issue in Luban for a dual color model. I’m trying to make this sea turtle with the body one color and the shell another.
I started with an SVG of each color group and created an STL in TinkerCAD for each. I bring it into Luban and everything lines up great.
As you can see in the pictures the green silk PLA (right extruder) isn’t putting down a full layer on the base layer. Then on the top you can see there is mismatch in layer height on the shell versus body.
The reason why I think this is a slicer issue is that I originally wanted to do green for the body and GID PLA for the shell. When i tried that, the green was on the left head and the GID was on the right head. I noticed the same thing happening with the GID on the first layer for the shell coming out of the right head.
Also, I just went through all the calibrations for the dual head righr before this. I did notice that the there was a small discrepancy on height on the breakaway model. Should I recalibrate the z-offset for the right head manually? Thanks in advance for any suggestions.
