Odd hatching on first layer
I get odd hatch lines going same direction as nozzle head slicing/workspace/wifi dl. Anyone else experience this?
It looks like maybe first layer setting in luban are massive over extrude or something maybe?
I’m no expert but I think it might be when your Z offset is too low.
You can try re-calibrating, or simply adjust the z offset up 0.05mm on the fly (probably only on the first layer) if you see this.
Hope that helps
Well, my first test print with the boaty I printed before this worked just fine. Is there issues with the “auto calibration”?
