A350 Cura Slicer Failed to parse file
Hello fellows.
I have a strange problem with SM2.0 A350.
I have a little model 30x30x4 with a hole that i try to 3D print. Filament PLA.
I can print it with Luban as a slicer, but if i use Cura 4.8.0 as slicer then A350 creates an error when loading the file, error: “Failed to parse file”
I’ve been all over the forum but haven’t found anything that helps me.
I’m using the print profile provided by Snapmaker and made machine settings as described in support
Cura profile guide
Now i have looked into the log, but it dosen’t make me any wiser on what the issue is.
Do anyone have the same experience and what to do, so the file will be parsed?
(It’s not possible to upload .log or .txt to the forum! Please change file to .txt).
SC_0.doc (3.1 KB)
Have you set the right language to cura?
Yes.
Also i did try Marlin(Volumetric)
The same error.
Make sure there are no unclosed brackets in your start and stop gcode. like ] or ) or [ (.
I have something similar happen.
.stl sliced in Cura.
The file is on USB
It loads/is parsed up to 95%, then it freezes. Then the message ‘FabScreen app has failed.’
And the objekt isn’t even that big.
@RAJensen @Thosam
We got some error messages in the SC log.
Could both of you PM the files to me so that we can try it at our end.
Thank you in advance.
Hi.
Here is the file Cura sliced and the original .stl file
Best regards
Robin A. Jensen
Denmark.
Cura_RPi Cam Front.gcode (103 KB)
RPi Cam Front.stl (30.4 KB)
try removing the commented out sections_3 part off the end of the file and try it again, just curious i started reading through it to look for a missing[ or ] but I am sick today and my brian needs rest but I was just curious what would happen if you remove that section, should make any difference to the print as it is commented out but never hurts to try
