SM2 A350 (Mdl80012) with Quick Swap kit with firmware SM2_V1.20.2_20240617
Luban V4.14 or Cura 5.10.0
Let’s start by acknowledging @Spaced - Precision is a never ending task or goal.
That being said, I’m not trying for high precision, just reasonable print jobs. My typical print is for jigs and artifacts to use around the house. I’m fine with a few bumps and some stringing. I’ve gone through the typical calibrations (@xchrisd @Hauke and others; thanks): bed leveling, extruder E-steps, flow rate with a 20mm cube, played with retraction and acceleration but could probably dial those in a bit more. I’ve done temperature towers but really haven’t seen anything better that 200 for most PLAs I use.
My last cube was 20.02 or 100.09%; I thought close enough. Walls were on the weak side 0.78 or 98.02% but for most of my stuff, I’m getting good enough results.
I just got frustrated, again, and started looking into the performance a bit more. I made a model in Sketchup with dimensions rounded off at 0.000 mm. The model I built was basically a bottle cap, but at 60mm outside diameter, with an inside diameter at 57mm; 3mm wall thickness. Upon completion, the outside was at the 60mm, but the inside was at about 55mm, and wouldn’t fit. I’ve seen this before and got annoyed,again.
I started playing around by making a model of various size blocks (think Califlower but different); 20, 40, 80 and 140mm with centers cut out at 10, 20, 40 and 80mm; again using Sketchup where I should be getting good measures. The results were from 100.4 to 103.2% of correct sizes. The inside sizes were 96.1 to 99,7% of correct sizes. The bigger the model, the closer to being correct, probably due to measuring error (digital caliper at 2 decimal places and 3-4 measures per measurement). Inside size is consistently smaller than the outside measurement. Using both Luban and Cura to slice (fast normal parameters), just in case. For the 20mm cube, I would have just changed the M92 XYZ parameters proportionally. In this case, that should affect both inside and outside, wouldn’t it?
Currently, M92 X403.00 Y401.00 Z406.00 B888.89 Current E233.40
(BTW - what is the B value for?)
The only think I can think of, the Sketchup STL isn’t translating correctly? I’ll have to dig into this one. But does anybody have any other recommendations on how to tweak this to get inside/outside measures better? Anything in SM that I’m missing?
Thanks
