Hoping someone can help. I prefer to use manual focus and controls when using the Luban software during my laser burns but since upgrading to 4.1.4 I no longer have this ability. I removed and reinstalled the software on both my win 10 machine and my Linux box. Both are acting pretty much the same. On my Linux box there have been a few times where I do not get any Y axis movement since the upgrade. Just wondering if I should go back to an earlier version or if this will be put back into the programming.
I never use luban to run a job, its saver to start and run the job from the touchscreen.
You should be able to do the manual calibration from the touchscreen.
Going back is also a good solution.
