Is there a solution to hold a 3KG spool with the A350’s.
I was not aware that they were so different in size and all my reels are 3KG.
Any suggestions or solutions that i can print to fix this ???
You probably don’t want to mount 3KG on the top of the SM 2.0 I’d suggest Melanchrom’s suggestion. Personally I use a wall mount for storing garden tools from home depot, and just stick the reel on one of it’s arms.
I’ll see if I can find the link to the product.
–EDIT–
I wouldn’t suggest going out and buying one just for a single reel of filament, but wanted to bring it up to suggest using your wall for space if possible. The machine takes up a large footprint as is.
In terms of what that mount can support though I hooked a ladder up to one of the hooks, then climbed the ladder and jumped a couple times. I’m 300lbs.
@Melanchrom 's solution is recommended. The origin filament holder is unable to hold a 3KG filament spool,
I use this on the top of my enclosure (like shown in the example picture):
Thanks my app didn’t spit out the links
no problem
I had the same issue,
Designed and printed this, works great!
Thank you everyone for all the amazing ideas.
