3d Printing toolhead not activating motor to feed filament
So I have an issue with my Snapmaker 2.0 A350.
The print head stopped feeding filament or heating up.
Changed the toolhead cable. It now heats up but does not activate the motor to feed cable.
Changed the toolhead for another 3d printing one. Still does not activate the motor to feed filament.
Anyone have any ideas? I did try to update the firmware but it says it is up to date.
Maybe your controller is defective, have a look here as workaround for figuring out:
Try to reroot the toolheadport with M1029, have a look here:
https://snapmaker.github.io/Documentation/gcode/M1029
Unfortunately it seems you will need a new controller..
The code you gave me worked! You are AWESOME! :grin:
