I’ve installed the bracing kit and the new tool head. I’ve adjusted the settings on the machine for the quick swap and the bracing kit.
When I go into Luban, everything falls apart. There is a duplicate entre for the snapmaker A350 in machine settings. If I choose one of them, I can’t send to the machine because it does not match. If I send the other, it keeps defaulting the width and height to 400. I send a file to the machine and the border runs about half the size of the expected image.
The other issue is that if I choose the 3.175 v bit and run the G-Code, it shows zero minutes for the print time and does not print anything.
There were no problems with the 50W CNC.
