The CNC settings tutorial have additional settings that my Luban software does not have.
For example: I created a text object inside Luban, and set its size and font. I center it on the axis grid, X 0,Y 0.
In the Luban software, I set it to “Snapmaker Original” with the CNC unit. I successfully connect via USB cable.
In the Edit window, under the configuration tab on the very right, there is NO “Relief / Vector / Text” option, only Transformation, Text, and Actions settings.
I set my origin point manually with the control pad, and set it to the center of my workpiece, and click “set origin” and the pad aknowledges this.
I run the path, and the router bit successfully goes around the perimeter of my text size, all along the origin Z height, which is just barely above the workpiece, 0.1mm, calibrated with your calibration card.
Then, I create the G Code, export the G code file, import it into the Worskpace of the Luban software. I see the text there, and it is aligned properly. The CNC bit is 0.1mm above the work piece, set in the center as its origin.
Then, when I press play, the CNC unit goes up along the Z axis, about 10mm, then begins to do the work, ABOVE THE WORK PIECE. It goes up and down in the air, as if the work piece was 10mm above where it actually is. SO it ends up carving thin air, instead of the piece.
Settings in the Workspace:
Machine coordinates = 0,0,0
Work coordinates = 0,0,0
What am I doing wrong here?
