Can not change any of the luban print options
all of the setting are grayed out and I can not change my initial layer speed or change to skirt.
Use the ‘gear’ icon to copy and create new editable print settings.
Thanks for your quick response! I had to export my print file and then reimport in order to make changes.
Yep, that confused me also. Really poor UI design. I originally thought, why don’t they concentrate on the hw, stop trying to reinvent the sw? But, they have integrated the 3D, CNC, and laser stuff. With varying success. Remember you can always generate the gcode with whatever floats your boat, don’t have to use Luban, escpecially since the wifi connectivity has major issues. That said, I’ve had quite good results using the default PLA settings, only thing I’ve tweaked is the feed rate, which was (as talked about before) way off. Worst thing with the default settings is bed adherence. Some have complained prints won’t stick, I have the opposite problem, things stick waaay to well.
