10W: why is the jog disables laser
Hello Snapmaker,
If you fire the laser via the remote control and try to move the laser, it will turn off!
Why is this?
Can’t make any fine adjustments!
Thanks
Response from Snapmaker…
“As to that issue, we have designed it that way for safety concerns.
However, you can try to set the work origin using Luban.
You can move the head with the laser turning on using Luban.”
Not sure what the safety concern here between using Luban or the remote control!
That does not make sense at all… If thy have safety concerns, why switch on the laser in the first place?
