I have had issues that I fixed. After testing a lot the only problem I can neither find nor google is that Luban backgroud images of tall objects are not adjusted accordingly to the heights of them. So for anything substantially higher then zero the positioning of artwork in the background image is somewhat useless. I hope that I was just to stupid to find it so I am posting here hoping for help.
To make clear what I am trying: 67mm high box, engraving should be filling the top to the corners, positioning is via camera capture. But the image taken is obviously assumed to be flat to zero heights and I cannot see where to but the adjustment even manually. Focus is NOT the problem, auto/manual both do engrave IF the vector hits the surface. But trying a rectangle on the box that goes into the corners make the laser go around the object by several cm…
Anybody? I’d highly appreciate!
Thank you very much guys!
Cheers,
Thorsten
