I have following problem:
I have a A350T dual extrusion printer head with a quick swap kit since last year.
The calibration last year was ok.
Now i download the newest firmware:
Levelling was ok.
z offset calibration: the header calibrate obviously the left nozzle.
then the header moves a little bit up and then - nothing.
I tried to level manually: the header crashes full speed into the bed.
nevertheless I move the header via touchscreen and calibrate both
nozzles with the card.
the first tip was right.
the machine settings were wrong.
Under “settings” the setting was “with screws” instead of “quick swap kit”.
I was not aware that I have to adjust the settings to this.
Last Fall when I installed the quick swap Kit I’d already set “quick swap kit” and
then following calibration was ok.
I thought the settings are stored permanently.
Nevertheless I’ve no idea why it was now “with screws”
