OK, context: A250, supplied coated springy bed. I do clean (Isopropyl 90% wipe with a paper towel so I have a little more fiber/friction than just a cotton ball to rub it off good). Printing PLA, various brands, various colors, and yes I know material matters. (I do not dry or dessicate mine, shoot me.) I know how to calibrate and always do a skirt of 3-4 lines so I can eyeball the squish and adjust the Z offset up or down if I think its a little wrong, and do tend toward more than less squish.
Parts adhere very well overall, rarely get an accidental release, usually do have to wait for cooling and pry gently with the putty knife and/or flex a few times to even lift a starting edge to be able to release the rest of the way. (Let parts cool first else the putty knife can gouge the bottom, esp with that kind of silky/pearlescent material that has a lot of extra goop [highly technical term] mixed in. All that said, large, mostly rectangular, flat bottomed parts do tend to warp up on at least one corner during say a 5-8 hour print, and I want to correct that. This is long after first layer deposition.
I’ve read the typical anti-warp advice and it mostly is taken into account by the A250 (with enclosure).
- Heated bed, clean, enclosed.
- Pre-heat the bed for more even heating, and to warm up the enclosed environment.
- Don’t use excessive part cooling (not a problem with the stock A250 head…it doesn’t cool that well at all heh).
- Rounding my corners (6-8mm radius on big parts).
- Only 2 bottom skin layers, low infill percentage. But I do want at least 3 top layers and side layers for rigidity, and inevitably that is going to still concentrate cooling stress on corners and want to lift them as the whole wall perimeter tries to contract.
The only thing I am not doing is using some sort of solution, gluestick, hairspray etc to promote further adhesion, or a full raft which is a pain in the [censored] to clean off the print bottom. I feel that cooling stress is going to overcome any adhesion not strong enough to make part removal severely unpleasant, and wonder if there’s a better way by design to reduce it (as rounded corners help, but do not prevent yet).
I am not a mechanical / thermal engineer. Any in the house that can comment?
Example idea, this is a topographical base for a small metal model with downloaded NASA mars data. I’m trying next little corner ‘feet’ with chamfered connections to the intended part, built into the design, kind of like a selective support or brim but hopefully easily knifed off. This is still just an adhesion trick really though, not dissimilar from a standard brim, or raft, or using some sort of goop…not design to mitigate stress directly. Would features like 1mm wide and tall slots in some sort of radial shape in the base (like quarter circles radiating from the nonexistent ideal pointed corner) designed into the bottom help to break up or release the stress concentration as the part cools?
