Noob : Any idea what is causing this effect?
Im using snapmaker white pla. The effect is mainly on the right hand side of the model and obliterates the text/script which should have be generated.
moisture in the filament probably.
that isnt the best quality filament anyhow
so many wet filaments out there fresh out of the bag…
I had a feeling you would suggest that
Thanks …
so do you or anyone have a preferred list of alternative filiment suppliers ?
matterhackers is my choice. the mh build series is inexpensive too. prusament is also supposed to be prime
may take some days to get that… so you might try some hatchbox from amazon for a faster delivery.
