Why U1 inactive nozzles stay warm?
Check the discussion here — the G-code needs a few tweaks:
Subject: How to turn off completely finished extruders while keeping others on standby in Snapmaker Orca?
Snorca is “blind” to long time gaps. It processes prints layer‑by‑layer, not by looking ahead at the overall timeline.
When a toolhead finishes its task on a given layer, the slicer simply tells it to park and drop to a standby temperature. It doesn’t consider whether that tool will be needed again 10 minutes or 14 hours later.
So even if a tool is never used again after the first few layers, the slicer still treats it like any other pause — keeping it warm “just in case” it’s needed on the next layer. This is why idle nozzles stay around 70°C for the entire print, even when they’re no longer in use.
