I normally use a Snapmaker 2.0 F350 with the Dual Extruder module & Cura as my slicer, and set the following in my Material settings (for both extruders):
Printing Temperature: 215.0
Printing Temperature Initial Layer: 215.0
Initial Printing Temperature: 205.0
Final Printing Temperature: 200.0
I also have the following for Extruder 1:
Standby Temperature: 175.0
And the following for Extruder 2:
Standby Temperature: 150.0
However, there are certain points in which both extruders have temperatures of either 200.0 or 205.0 (at the same time), and are not in the process of changing, they both just stay there until the next extruder switch. These are not Standby or Printing temperatures, so they should never be staying at those temperatures, especially at the same time. At this point, it hasn’t caused enough problems that it is unbearable, but there may come scenarios where it is. I have noticed (unsurprisingly) that there is more oozing when this happens, which is obviously not good. This only started happening very recently, even though I did not change my setting (at least none related to temperature). Any ideas?
