My Prusa do the whole calibration without me needing to use a calibration card, in the last step. Why Snapmaker needs that? Thank you!
My guess is that the last step is for fine tuning the z-offset over all measured values.
Are there any way to make that automatic/automated? @admins
From https://help.prusa3d.com/en/article/first-layer-calibration_112364 :
The printers assembled in the Prusa factory are already fine-tuned and this calibration is needed only in case you build the kit version at home or change the nozzle.
So I guess the answer is, Prusa did that step for you ![]()
More seriously, it looks like Prusa has you do the same step using a live first-layer print, instead of using a gage such as the calibration card. You could do the same thing with a snapmaker - just hit OK to save the (very very high) default offset, then start a print and lower the Z offset until it looks right. The Z-offset setting will be saved if you do this using the touchscreen.
Mine wasn’t assembled by Prusa, was by me. @edf What’s the thickness of the calibration card? Cheers!
0.11mm, by digital caliper. It’s what shipped with the SM2. I find a 0.127mm (0.005") feeler strip to be more repeatable, but you have to acquire the knack of using it.
