Why is the J1 hot-end temp limited to 300C?
If the hot-ends come equipped with pt100 sensors, why is the temp limited to 300C? Those RTD’s are good up to 500C, so what is the limiting factor?
Mostly I guess it’s the ptfe tube in the heat break.
Ptfe fumes are toxic for birds if they become too hot.
Maybe, but the PTFE only makes contact with the top of the heat break, so it should never even get warm. If the top of the heat break or the heat sink get anywhere near 300C then you’ve got bigger problems than PTFE offgassing lol.
I don’t see any reason that the max printing temperature wasn’t set at 350C at least. It should theoretically be capable of 500C, but I can’t imagine why anyone would ever need a set point that high.
Maybe they just used cheap heater cartridges with a low rated max operating temp. Hopefully someone from Snapmaker will chime in and let me know what the limitation is so I’ll know what I need to replace.
Genuinely just curious. What do you need to print that’s over 300 C?
It’s starting above 200 degrees to be toxic.
My Google search differs from 200-280°C.
You are right, it should never be so hot…
Shoot a ticket and let us know your progress:
I print almost exclusively with PC. It is achievable at 290-300, but I would like to do some tests at higher temps and speeds. I would also like to attempt to print PEEK for specific reinforcement parts. Maybe other filaments as well that I haven’t yet learned about because I don’t currently have the capability and therefore haven’t bothered to research.
Support said that the limitation is the heater cartridge. They are rated for 300C apparently. I’m ordering some new ones from Slice Engineering that are rated to 500C.
I would be very interested in hearing how that goes, I would like to possibly go to 350, or a little higher. Hopefully there aren’t any other parts in the head that would suffer?
Cheers,
David
I’m reminded of Zack Freedman’s video about filaments and something about how PEEK is basically satan. :joy:
im sure a hotter hotend would work but most filaments still need a hot chamber and hotter build plate than what the J1 can support. you could print PEI on it once, then your plate wont be PEI coated
I don’t think I would have any luck attempting a pure PEEK filament. PEEK-CF might be doable since the CF should help prevent warping. Otherwise, I might consider one of the many different PEEK blends out there that are more achievable at lower chamber temps, or even PEI. There are quite a few interesting options.
I’m installing a chamber heater, so I can maintain a 60C chamber. Not ideal for regular PEEK, but there are blends and similar filaments that should work at that temp.
The J1 print bed can handle 120C as well if you change the firmware. Add some nano polymer adhesive and a disposable build surface to the equation and it should be fine. Hypothetically lol.
Hello, did you have some news about swapping heating cartridge ?
I’m looking for somthing to print Fiberon™ PPS-CF10, recommended printing temp is between 310 and 350°C.
Yes I used slice engineering industrial heater cartridges rated to 500 degrees. I suggest removing the silicone sock if you go over 300 degrees though. I am also using volcano heater blocks and nozzles with the stock heat break. If you try to use the stock heater blocks you’ll probably have heat creep and clogging very quickly because the heat break is threaded so deep into the heater block. That’s just an assumption though. I never used the stock heater blocks at all before switching to volcanos.
