I’ve tried to lasercut material, triplex till 2 mm thick… cardbord till 2mm thick…
Whatever I do, I can’'t make it cut using the Get Started chart here on the forum… What do I do wrong?
I’ve set up the laser multiple times with the calibration squares on the left of Snapmaker JS. they cutted instantly through paper, the hight was okay. But then. I want to cut this item for example… but it won’'t cut, also with another pass or extra run from pass 1 till the 4th time… it doesn’t.
Well, maybe I had to adjust the focus of the laser manually.
Now I tried it with the following settings and it’s alomst cut through… yoohoo
Cirkel of 2cm diameter… speed 150, 5 passes, 0.1mm per pass. The cut is still sharp, so I make it six instead of lowering the jog speed. I guess that would be better than the bleeding I got the previous times (although that could be from the bad manual focus)
