Vibration Compensation Firmware Open Beta for 2.0 Series (A/AT/F Models)
Currently, we only received one issue report regarding this in the community. Could you please let me know your ticket ID so that I can let our support team to prioritize your request?
Hello,
sorry, i send the email (548770) now i was busy printing,
thank you
@Janik This is a good question. However, I’m sorry that we have not yet made printing profiles dedicated for this Vibration Compensation firmware version.
  1. If you’re using the default settings in Luban with Vibration Compensation enabled, you won’t need to change any other print parameters.
  2. If you want to push the print speed to the limit—either by adjusting Luban or using third-party software—then it’s recommended to increase the nozzle temperature by about 10°C. Also, keep an eye on the minimum print time per layer (ideally 6-8 seconds). If you notice any issues with overhangs or corners, you may need to tweak the firmware K-value.
Hi everyone. I have a simiar issues with layer shifts on Y-axis as described by
It seems to be a bit unpredictable, I can run some prints at high speeds (120 mm/s) with the new firmware with good results and others with the same settings show the layer shifts. If I run slower (max 100 mm/s) everything is fine again. So some steps are skipped by the bed. I have a Snapmaker 2.0 350T, single extruder. Is this just a limit of my individual machine or is this something which can be addressed by the firmware itself?
Hi Jade! I wanted to test the new firmware as well. After solving the issue with my noisy linear rails- I still have issues printing some benchy properly. 20mm Lead Axis and Single extruder. I have a little more stronger Cooling Fan. I ran trough the compensation tuning but it seems I’m getting really heavy under extrusion problems that I’ve never occurred before. My E Steps & K value are also calibrated
Still
I think you are printing too hot and maybe your filament is wet.
If you roll the firmware back, is it a different behavior?
Thats why I used different filaments. Grey went to the Dryer before and while printing, the mint green was a complete new Spool out the box. Both printed at 195 degree
Firmware rollback might sound like a good idea. Having inconsistencies since months and can’t find the root issue
Maybe its to cold. With my Prusa Mini my standard Temp is 220 and 230 in first layer. With Inputshaper and Speed profile. I cant print with lower temperature without skipping e steps.
It seems to be something speed firmware unrelated. I tried with the standard software and the lines are still not 100% consistent.
I will open up a thread for this.
Did anyone else noticed a bigger fluctuation of the Printing temperature? Mine is ±2deg swinging around 200deg while printing.
Here is another user with layer shifts using simplify3d:
I’ve read through this and the previous thread, and didn’t find my answer so apologies if I’m asking for something already available.
What is the status of open sourcing the vibration compensation firmware? I see @Mayco had previously asked for it, and @Riskey had said they would eventually release it, but that it seems they were not yet ready to open source it at the time. I don’t see any further updates after that.
Now that the vibration compensation firmware is considered stable, perhaps it’s time to release thee source.
Reminder that Marlin is licensed under GPLV3 so you must release your modifications to the code: Marlin/LICENSE at bugfix-2.1.x · MarlinFirmware/Marlin · GitHub (also, you’re technically already in violation of the license given that any binary release must be accompanied by full source code release and you’ve been releasing binaries for a while now.)
Sorry I am just now getting back into this thread.
Right after the bball print in July, I printed a full Y-scale cylinder tower. No issues of shifting noted.
I may pursue xchrisd’s line of thought, perhaps after a couple tests of the newest beta FW. I haven’t really kept up on the updates here so I should probably review.
Hi, I believe the Jerk setting is crucial for resolving Y-axis layer shift issues. While it might add a little to the print time, setting it around 5 is kinder to the printer.
There might be a decision process in progress about way of releasing the vibration compensation firmware as main branch for every snapmaker.
I’m asking them to consider a flip switch - to enable or disable the tech instead of making it the only available option. So it might be that open source of it will happen after this… Who knows.
100% with you on licensing issues.
GPL doesn’t really care what your process is. If they’re distributing binary files, they must distribute source code.
They don’t have to put it on GitHub or make it particularly easy for anyone to look at (GPL says they can just drop a zip over on an FTP server or something), but it’s a violation for them to distribute a binary (e.g. post the binary on these forums) while not distributing the source used to build that binary (e.g. every post containing a binary should also be containing a source code link, if they want to have a mirrored GitHub repo with tags that they can link to, that’s great, but they must at least link e.g. just a zip file of the source code used to build that binary code).
I’m not trying to be mean about it (and it’s not like I actually have any plans of legal action), it’s just the terms of the license that they’re bound to. I’m a developer myself and know how at least our legal team is deathly afraid of GPL. If you use any GPL code in your project, you need to make sure you keep it properly isolated from other code to ensure that the copyleft mechanism can’t be used to force your team to open source proprietary IP (there are many ways to do this, I see that the SM team has been moving more of their code into the HMI which doesn’t seem to use GPL code as a base, but any Marlin modifications they make are, unfortunately for them, bound by the license).
tell this to bambu :slight_smile:
we all know how this work, but as individuals have little power to enforce this. The sole biggest issue with open source - is no united force of enforcement…
All this off topic tho…
I mean, one simple way to try and force them to comply is for the community to keep pushing for compliance. If the forums were just full of “we’re not talking till you release the source”, the company either dies (since no one wants a product that has no community) or they release sources and we all happily go back to an engaged and thriving community.
Hi! I’m also trying to get into Orca Slicer but using the single extrusion module. Can you share your profile/ settings for Orca?
Currently trying to troubleshoot my printer
There are built in profiles in Orca… Use those. They came from MacDylan.
Hi everyone
I also just started playing with the input shaping firmware as well.
I noticed a weird behaviour where linear advance stopped working when I activated input shaping.
Without the input shaping the linear advance looks as expected (left).
When priting the same gcode with input shaper enabled all the lines look like there is no pressure advance at all (right):
Some defects are also visible when printing a benchy.
The layer stacking becomes much worse and the smoke stack becomes oval.
Not sure if these problems are related though.
Has anyone encountered a similar issue?
Thanks in advance :slight_smile:
