Using 10w laser to laser on an ipad
Hi all,
Has anyone out there used their 10w laser to write something on the back of an iPad? If so would you mind sharing your settings with me?
I have used an IR and 40W to write on plastic things. Not a tablet or Ipad yet though.
I would suggest start with the settings for Black Acrylic, and adjust from there. Test on a similar material first though, and adjust the speed and/or power to get the desired result.
Suggestion, find a similar material, like thin aluminum plate and burn away. I use sacrificial material all the time to test an idea. Your idea may me suitable for engraving, I like the finish look better than laser, but it should do fine.
