Upgrade to 4.5.0
HI, i use a Mac 15" Mid 2012 as shown in the photo attached.
Schermata 2023-01-15 alle 07.25.02
I installed and used Luban 4.4.0
the upgrade to 4.5.0 crash when i generate G_code file, There’s a incompatibility with so.
So i installed the old version 4.4.0 but now it’s occurred a new error message, “the slicing failed because the model is too small”, but it’s not so…
Hi cesare76m, Luban v4.5 doesn’t support macOS 10.13 & 10.14 :cry:. And for the problem you’ve encountered with v4.4, the reason might be some configuration file errors. You could try the following steps:
  1. Find the configuration file in the following path and back it up somewhere else.
    • Windows OS: C:\Users\admin\AppData\Roaming\snapmaker-luban\snapmaker-recover
    • macOS: /Users/admin/Library/Application Support/snapmaker-luban/snapmaker-recover
Note: Replace admin in the path with your username.
  1. Delete the whole snapmaker-luban folder (the one in the path above) .
  2. Reinstall Luban v4.4.
That’s a shame. There’s likely no technical reason for that requirement. If Luban 4.5 doesn’t support MacOS 10.14, and 4.5 is required for the dual extruder I will be canceling my pre-order.
i think that you can use another slicing software…
thanks, i solved the problem, it would be better to not start installation if there is an incompatibility. Bye bye
Hi snapUser, sorry for the incompatibility… you could try other slicers. I’ll try to collect usable profiles of other slicers and post a collection thread. :blush:
I think there are still a lot of Mojave users. It would have been nice to continue to support it. Regardless, I was able to successfully cancel my pre-order.
