Hey guys,
I’m just wondering if it would be better to unload the filament every time we finish a print so that the extruder will be empty while the Snap if turned off or idle for some times.
What do you think?
At the beginning of each print, the print module purges any filament that is in the hotend. So once the hotend is up to temp, it cleans things out. I keep the filament hooked up, and just change it when I need to change color or type of filament.
There is one case where I’d do it, and that’s if the filament needs special storage (usually this would be stuff that rapidly absorbs water from the air, like nylon or PVB).
Ok thanks for response!
