Hi everyone,
I’m having trouble with multi-color prints on my Snapmaker U1. When printing raised/embedded text on vertical walls (specifically black text on a red body), I get two main issues:
Blobs and stringing on the text: The black filament forms small blobs/ooze around the letters when transitioning between characters.
Color contamination on the red wall: The black nozzle leaves small black streaks/marks on the red base wall around the text area.
Setup details:
Printer: Snapmaker U1 (Toolchanger Direct Drive)
Filament: PLA (Base) + Black PLA (Text). Red is mate and yellow is basic.
Slicer: Snapmaker Orca (default profiles)
I’ve already checked the purge volumes, but since the U1 uses independent toolheads, this seems to be related to retraction or nozzle wiping between tool switches.
Has anyone tuned their retraction distance/speed or standby temperatures to get completely sharp text without nozzle oozing? Any advice or recommended settings would be greatly appreciated!
Thanks in advance.
One question: are you using a purge tower? I ask because of the color contamination issue. Use a tower and you’ll see that contamination doesn’t occur. As for the other issue, what I see is excessive temperature in the filament, which causes those strands or wet filament. Also check the layer fan settings in case they’re too low. It could also be retraction, but seeing those filament lines makes me lean towards moisture or excessive temperature.
Hi @nilose2014
Thanks for the reply!
I am using a purge tower. However, the black and yellow filaments have been kept in ambient conditions for about 3 months, and notice that the text is printed on vertical walls.
The first thing I’ll do is replace them with new filament and dry the old spools. I will run another test print and see the results. If the issue persists, I will lower the temperature and finally tweak the retraction settings.
I won’t be able to test it until next week, but I will update this post as soon as I do.
sanity check, do the black marks show up on layers where the black toolhead never even prints? that’d be parked-nozzle drool rather than wet filament
Thanks @MasterPrinter1
Sometimes it happens. It was more evident when I had selected “Avoid crossing walls”. Without selection it’s minimum.
However, I will take note of that.
interesting that avoid-crossing-walls made it worse, the longer detour paths would give ooze more time to drop over the text honestly
Try lowering the extrusion temp of the black by 5C. I started having this with Sunlu PLA, because there was some slight stringing. Lowering the extrusion temp reduced the bleeding color.
Thanks @KCC_703
I will try. I’m thinking printing the walls separately and horizontally to print faster, because vertical printing is about 10h printing ( changing toolhead ). Definitions of the letters will improve but not of the cube.
Hi @MasterPrinter1
With settings:
- Quality: Avoid crossing wall → enabled
- Strength: Wall loops → 3
It was actually worse with matte filament.
With such small fine text is going to be a bit hit n miss printing without a 0.2 nozzle, just as a thought does the text need to be raised or could it be flush in the model as then you could print the walls first and the text colour in the gap afterwards which /should/ help?
Thanks @ColdCoffee
I didn’t know about this feature. I will try it.
I’m testing because we have to make 100 chemical elements and I don’t want to waste so much material.
Just to make sure: what did you calibrate?
I suggest first going here:
Ultimate filament calibration guide:
I do not think that your text is too small. I see the last photo you posted, and it looks big enough to be printed well with a 0.4mm nozzle.
I suspect that some tuning will solve this. Also don’t forget to set the ‘retraction on toolchange’ lower than the usual 10mm. This is to be changed per tool if I remember correctly. I suggest trying out a value between 2 and 4mm.
Hi @RepairAndTinker
Settings are default.
I will start with the calibration tests and choose the optimal settings for it
Thanks for settings and video.
I had similar issues with one filament where it would blob a bit here and there and calibrating it completely fixed the issue 100% I hope it can work some magic for you too
Thanks @ColdCoffee
I’m using snapmakerorca to insert text on box. It’s the best way to change it for 100 elements.
Maybe I will change infill pattern. I will see.
Tomorrow I will start with calibrations and going on.
As others have said filament calibration, drying and fan speed is important but not the whole story. I print models that have lots of small details like this and I have been in calibration hell the last week trying to get it to work like they do on my P1S. The U1 for some reason is VERY picky with calibrations and it’s a mess if it’s not perfect. I found it took several full rounds of temp, pressure advance (despite what tutorials say, I’d go slightly higher on this one), max flow rate, flow ratio and retraction on all my filaments to get it clean. It also took editing the change filament G-code to make the nozzle scrub every change. I found a lot of stringing was coming from stuff stuck on the nozzle. I also have found that the default 30mm³ value for the prime tower is definitively the minimum. Below that I was getting terrible stringing.
Here is my change filament G-code to use. I am using the paxx12 extended firmware so I am not sure if this is compatible without that. Use at your own risk if you wish.
;===== date: 20260607 =====================
; Change Tool[previous_extruder] -> Tool[next_extruder] (layer [layer_num])
; max_layer_z [max_layer_z]
; max_print_height [max_print_height]
; print_sequence [print_sequence]
local move_z = 1.5;
local max_speed_toolchange = 350.0;
local wait_for_extruder_temp = true;
position[2] = position[2] + 2.0;
local speed_toolchange = max_speed_toolchange;
if travel_speed < max_speed_toolchange then
speed_toolchange = travel_speed;
endif
if print_sequence == "by object" then
if max_layer_z < ((max_print_height - z_offset) - 2) then
move_z = z_offset + min(((max_layer_z - z_offset) + 2), max_print_height);
endif
endif
"G91
G1 Z" + move_z + " F600
G90
"G1 F" + (speed_toolchange * 60) + "
if previous_extruder != next_extruder then
"ROUGHLY_CLEAN_NOZZLE
endif
if wait_for_extruder_temp and not((layer_num < 0) and (next_extruder == initial_tool)) then
"; " + layer_num + "
if layer_num == 0 then
"M109 S" + first_layer_temperature[next_extruder] + " T" + next_extruder + "
else
"M109 S" + temperature[next_extruder] + " T" + next_extruder + "
endif
endif
"M400" + "
"T" + next_extruder + "
MOVE_TO_XY_IDLE_POSITION_EXTRUDER
endif
if filament_type[next_extruder] == "PVA" then
"SET_VELOCITY_LIMIT ACCEL=3000
else
endif
"G90
Another thing I will add, with protrusions like your text, I have found that 0.1mm protrusion will be legible and clean. Above 0.2 it gets droopy and the bottom suffers from the overhang.
Thanks @manray005 .
Thank you. I don’t have enough time to try various variations, but with more time, I will give it a try.
