U1 BMCU-Klipper - Multi-Color / Multi-Material System - Up to 32 Filament Sources
Hi everyone,
I’d like to present my BMCU integration for the Snapmaker U1.
BMCU is a relatively inexpensive, widely available and modular multi-color / multi-material system. Complete units are easy to buy, but BMCU is also a very good DIY project - you can print the enclosure yourself, buy the electronics and remaining parts, and build the entire unit from scratch.
Communication with the printer is handled through USB.
If we need more materials, we can simply add additional BMCU units. Each module provides four additional filament channels.
The Snapmaker U1 has 32 logical material sources. The first four belong to the native U1 sources, so while keeping all of them available, we can add up to 28 BMCU channels - seven complete BMCU units.
I tried to design the integration so that it makes use of the Snapmaker U1’s capabilities as broadly as possible, while at the same time not forcing the user into one specific configuration.
Each BMCU channel is completely independent.
There is no need to assign an entire BMCU to a single toolhead. Every individual channel can be routed to any of the four U1 toolheads.
For example, we can:
  • connect all four channels of one BMCU to a single toolhead,
  • split the channels of one BMCU between several toolheads,
  • use several BMCUs with a single toolhead,
  • leave some toolheads on the original Snapmaker feeders,
  • or completely replace the stock feeders with BMCU channels.
The last option is also useful when normally printing with just a single filament.
BMCU can work as a fully automatic feeder - it can both feed filament into the toolhead and actively retract it when necessary.
There is also an option to leave the last filament loaded after a print has finished.
If the next print requires exactly the same filament, the system simply uses the filament that is already loaded in the toolhead.
If a different material is required, it first safely unloads the currently loaded filament and then loads the correct one.
This can be quite useful if you frequently print with the same filament.
BMCU can also be freely combined with the original U1 feeders, so there is no need to choose between one system or the other.
The integration also includes its own configuration panel.
Among other things, you can configure the routing of every channel, load/unload distances, individual material sources, as well as tip forming.
Tip forming can be configured depending on the material type and nozzle, so you can create different sequences, for example, for rigid and flexible filaments or for different nozzle diameters.
You can also configure temperatures, extruder movements and the point at which the toolhead is parked, allowing part of the material change process to be performed in the background.
In the configuration shown in the video, I use four BMCU units - a total of 16 additional filament channels - connected across all four U1 toolheads.
Video:
Repository:
The project is fully open source.
If you have any questions, ideas, an unusual configuration you’d like to test, or if you find any issues, feel free to ask here or open an issue on GitHub.
P.S. It’s a little difficult to show an entire 16-color print because it takes quite a while, and at the same time you have to survive holding the camera long enough for anything useful to be visible. I did, however, record around 30 minutes of the actual printing process and I’ll try to upload it later today.
Three additional filament channels.
Each BMCU has four independent filament channels.
On the U1, T0-T3 are the four native Snapmaker sources, while BMCU channels start from T4.
So seven BMCU units provide 28 additional channels, for 32 logical material sources in total.
12 additional filament channels.
You can assign all four BMCU units to a single toolhead and simply stop using the original Snapmaker feeder on that toolhead.
In that configuration, you would have 16 BMCU channels on one toolhead while still keeping the three original Snapmaker feeders on the other three toolheads - so 19 available filament sources in total, which is 15 more than the stock configuration.
You can also use filament connected through the original U1 feeder together with BMCU, but there is one limitation - the stock feeder cannot actively retract the same filament back out of the shared path.
Because of that, it is best used as the final filament in a print, or in situations where no later automatic unload is required.
It can also be treated as an additional “external source”, similar to the external spool option on Bambu Lab printers.
You do not have to unload the filaments that are already prepared in the BMCU units. For example, if all of your BMCU channels are already occupied by materials you normally use, but you temporarily want to print something with a completely different filament, you can simply feed that material through the original Snapmaker feeder and use it as an additional source.
Each BMCU unit still adds four independent filament channels.
If the original U1 feeder were able to actively retract filament in the same way as BMCU, stock sources and BMCU sources could be mixed completely freely. Unfortunately, that is simply a hardware limitation of the original U1 feeder.
I explained all of this in more detail in the video as well, so if you’re interested, I recommend watching that part.
I agree with Boxkite. You have not shown the detail (so far as I can see) of the manifold required to feed several different filaments into one toolhead, but the exiting Snapmaker auto-feeders are unable to retract filament so the BMCUs have to manage the feed from the auto-feeder as well. One BMCU doesn’t give you four additional filaments, only three (because the fourth channel has to manage the existing filament).
Manual rejigging does not count as an additional filament!
My comment is correct and referred to this statement only:
Huh. I am very close to integration of a ViViD unit, but I think I might abandon that in favor of this. Nice work. I’m certainly going to give it a go.
