First of all, hello everyone,
I want to use my Snapmaker Ray 40W device with lightburn. I am connected to my device via wifi and all software is up to date.
I installed snapmaker-ray-40w-v1.lbdev by importing it in the first installation.
First mistake I made;
Error:22
Feed rate has not been set or defined.
On or near line 0:
Everything seems normal but I get this error at random times.
Second Error
The axes seem to be different, according to the research I did on the internet, I had to use “G10 L2 P1 X0 Y-400” and if I want to return to luban, I should enter “G10 L2 P1 X0 Y0” again.
What should I do to use my Snapmaker ray 40w device completely smoothly, can anyone who uses it give me the settings?
error:22
The feed rate has not yet been set or defined.
On or near line 0:
error:22
On or near line 0:
error:22
On or near line 0:
error:22
On or near line 0:
error:22
On or near line 0:
error:22
On or near line 0:
error:22
On or near line 0:
work stopped
Stream completed 0:13
error:22
clear
error:2
Numeric value format is not valid or missing an expected value.
arrow
[I][PLAT]reset coordinateoffset
starting stream
Layer C00
a picture or something stays where it is while rendering. I couldn’t use my device properly, when I use “lightburn”, when I do “G10 L2 P1 X0 Y-400”, the screen is like in the picture, when I adjust the program, I can at least give direction, but it is annoying that it randomly gives this error when processing parts in an emergency, how do I solve it. if anyone has a setting file, can they share it?
Error:22
On or near line 0:
I also could not find how these settings should be when processing or processing or cutting pictures, can you help me?
SETTING:
