Hi everyone,
I’ve been having trouble with an external USB camera (Logitech C270, 720p) on my Snapmaker U1 running paxx12 Extended Firmware v1.4.1. The camera would show up correctly in v4l2-ctl --list-devices and the V4L2 Controls panel, but the video stream kept failing with VIDIOC_DQBUF: No such device, and dmesg showed constant USB resets (usb 3-1.3: reset high-speed USB device…) roughly every 13-14 seconds.
After digging through SSH, I found that stopping the control-v4l2.py process for the USB device (/dev/video18) immediately fixed the stream — kadri started flowing normally as soon as that process wasn’t polling the camera. So it looks like my particular camera doesn’t handle the V4L2 control-polling well and resets under that load.
Since my C270 unit is clearly getting old, I’m planning to retire it and buy a new webcam instead of fighting this. Before I do:
Has anyone had reliable long-term success with a specific webcam model on this firmware (ideally small and cheap)?
Is the C920/C920S known to behave better with the control-v4l2 polling than the C270?
Is this a known issue with certain older UVC chipsets, or is there a fix/workaround planned for the control-v4l2 service itself?
Must be UVC-compatible (almost all modern brands are, but avoid completely unknown no-names from AliExpress without clear specifications - that’s where you often find “crappy” UVC implementations that are just as buggy as your old camera).
And yet, due to the limited budget, I’m asking for advice on a compatible cheap 1080 p camera from AliExpress
Happy to share full SSH logs if that’s useful for debugging on the firmware side. Thanks!
Here’s a summary of the steps to get it running. Maybe someone will find it interesting. Personally, I don’t understand any of this.
Restoring a USB camera (Logitech C270) on Snapmaker U1 (paxx12)
Cause of the problem
The `control-v4l2.py` process, which handles the “V4L2 Controls” panel for the USB camera, periodically polls the old Logitech C270 camera. The camera can’t handle these requests and resets at the USB level (~every 13 seconds), which causes:
the camera’s LED to flash,
the video not to appear in the Preview (endless spinner).
The problem recurs after every printer reboot because control-v4l2.py for the USB camera restarts automatically.
Quick fix (must be repeated after every reboot)
- Connect via SSH
Open PowerShell (Start → powershell) and run:
ssh root@192.168.1.9
Password: snapmaker
2. Find the control-v4l2.py process for the USB camera
ps aux | grep control-v4l2
Find the line with --device /dev/video18 (this is the one for the USB camera; do not confuse it with /dev/v4l-subdev2—that’s the built-in camera).
3. Stop this process
kill
(replace with the PID from the previous step)
4. Verify that the camera is free
lsof /dev/video18
It should be empty (no process is holding the device).
5. Verify that the USB resets have stopped
dmesg | tail -5
Wait 30–40 seconds, then repeat the command—no new lines saying “reset high-speed USB device” should appear.
6. Start video capture manually in the background (it will continue even if the SSH session is closed)
nohup /usr/local/bin/fake-service --retry 3 /usr/local/bin/capture-v4l2-jpeg-mpp --device /dev/video18 --jpeg-sock /tmp/capture-usb-jpeg.sock --mjpeg-sock /tmp/capture-usb-mjpeg.sock --h264-sock /tmp/capture-usb-h264.sock > /tmp/usb-capture.log 2>&1 &
- Check the result
Open the V4L2 Controls / Preview page in your browser and make sure the image appears and remains stable.
Important
Do not open the Exposure/White Balance advanced settings section for the USB camera in the web interface—this restarts control-v4l2.py and will once again cause the camera to enter a reset loop.
This is a temporary solution—it resets after every printer reboot, so you’ll have to repeat steps 1–6 each time.
Long-term solution
The camera (Logitech C270) is considered obsolete for this task. We plan to replace it with a newer model (such as the Logitech C920/C920S), which will likely handle the control-v4l2.py polling better.
