Top filament feed with enclosure
My enclosure for my A350 sits against a wall on the left side blocking the factory entry point for the dual filament feedthrough. I need to feed through the top.
I’m considering swapping the left side and top panels to relocate the factory cut hole. The hole could go in either the back right or front left corner.
Alternative is to create new feed through in the top directly over the print head but not using the factory feed tubs. Drawback of this is it leaves a tight bend in the filament when returning to home position.
Suggestions for a feed through the top for dual print module? It needs to be something out of the way using CNC or Laser modules.
Avoid the tight bend.
Create a new feed in point where it suits you best though.
